2010 Hummer H3 will crank but won't start
Old 10-28-2023, 07:22 AM
ianq's Avatar
Default H3no start
If the CEL is ON, there is a stored code somewhere. How many mikes on it?
Does it have a sunroof? If so, has the passenger side floor ever gotten wet?
Easy stuff first.
Does it still have the crappy azzed OEM battery terminal connectors? If so, hack them off immediately and replace with your favorite aftermarket brand, like Stingers. The OEM battery terminal connectors are the known #1 cause for H3/3T electrical gremlins.
. Whats the sunroof issue? I do have a leaky one and floor has been wet
Old 10-28-2023, 02:17 PM
Golden Hurricane's Avatar
Ianq
If you have had a wet carpet, especially if the passenger side has been wet, the BCM has probably had moisture also!
A. Read the first suggestion about the sunroof drains! This information is located just above the Topics Area on the Hummer H3 forum.
B. You may also want to read several posts regarding how owners have "cleaned" the BCM... actually pretty simple. Just be certain to follow the advice. Ask for clarification on anything you don't clearly understand.
Lots of great people on this forum are willing to help you. Happy Trails
Old 10-28-2023, 02:21 PM
The Sticky you should read:
Finally a fix for clogged sunroof drain tubes
Old 10-30-2023, 10:35 AM
And............. avoid digging up 6 YEAR OLD Threads! READ: Old Threads/'Necro-Bumping'
Mrfaceman23
11-23-2021 12:06 PM
jfitz
04-01-2020 11:04 PM
bureau13
03-19-2020 10:26 AM
Oberbreckling
01-16-2020 08:58 AM
HUMmer-h3
01-02-2020 01:27 PM
Quick Reply: 2010 Hummer H3 will crank but won't start
