2006 H3 won’t start
Old 10-24-2019, 05:42 PM
Peepsdada's Avatar
I bought a brand new starter relay and tried that as well- hummerz- I’ll get resting voltage again in a few, just started raining (thanks for all the help!!)
  #22
Old 10-24-2019, 05:51 PM
I already ruled out the relay when you swapped above. STOP, throwing parts at it..
Btw, did you scan for any codes?
Does your temp gauge run high when driving?
More information needed.
  #23
Old 10-24-2019, 07:15 PM
Peepsdada's Avatar
Scanned and throws no codes. Temp is fine when running.
  #24
Old 10-24-2019, 08:13 PM
what exactly does no start mean. does it crank and not fire or is there no action to the starter at all?
  #25
Old 10-24-2019, 09:21 PM
this thread reminds me of a game I use to play:
  #26
Old 10-25-2019, 08:20 AM
Peepsdada's Avatar
Took the truck to the shop- I gave up on figuring it out myself. I’ll keep everyone posted.
  #27
Old 10-25-2019, 12:38 PM
Ejwins's Avatar
You have to rule out electrical first. If you have a multimeter, test obvious points such as at the starter, the pcm, at the fuel pump if you have access. Also if you have a scan tool or a tech2 or tech2win, look at the live data with ignition on to check voltages and other signs of problems with ignition and fueling.
But checking for voltages at common places that must have a signal to crank I think is important 1st step. Also regarding the battery, even though the voltage is 12.9 that doesnt mean much necessarily, that could be surface charge. Run the headlights for 2-3 minutes, then check the battery again. Did the voltage drop a significant amount? If it did then you have a bad battery my friend.
  #28
Old 10-31-2019, 12:08 PM
Peepsdada's Avatar
Took the truck to the shop. EVERYTHING tested out fine and the mechanics still can’t figure out what’s wrong with my truck. This truck is a POS. Any other suggestions before I drive it off a bridge?
  #29
Old 10-31-2019, 12:39 PM
There's a good chance if the no start condition did not occur at the shop, the mechanics never checked anything. Believe me I know. I've had techs, that would go to the parking lot, to check for a no start condition, and if it started, the tech would return the keys/paperwork to me stating "this 1 is fixed". Never checking anything.
H3ummer
08-21-2023 09:51 AM
Humm3r
04-05-2021 01:21 PM
chrisg75077@gmail.com
11-01-2019 10:35 AM
ffmf2101
11-19-2018 08:37 AM
real7446
01-05-2008 07:47 PM
Quick Reply: 2006 H3 won’t start
