08 hummer H3 3.7L question about TEMP gauge!!
#41
Do you know where the ambient sensor is located?
#43
Still fine? Yes, you can also drive at 220°F, you could even drive with the temp higher. However, every time you run the temp higher than normal, you are causing excessive wear on the engine. I recommend to stay
#44
When diagnosing it helps to know the ACCURATE, ambient temp & iat, to determine a source of high ect.
Cgiraldo
07-10-2019 05:15 PM
casey930
04-25-2012 09:17 PM
RealJeep
30
07-01-2011 10:24 AM
