08 hummer H3 3.7L question about TEMP gauge!!
Old 09-26-2019 | 08:42 AM
amrg's Avatar
Your coolant temp is 194*
Whats the issue here?
  #22
Old 09-26-2019 | 08:50 AM
Ismitty41's Avatar
But it will get up to 208 210
  #23
Old 09-26-2019 | 10:53 AM
Which is completely normal.
While low speed wheeling in PA I've seen my 07 get to 219, still no big deal.
That said, a coolant drain and refill for an older truck is not a bad idea since you likely have no record of when it was last done.
  #24
Old 09-26-2019 | 11:20 AM
Ismitty41's Avatar
Ok thats makes me feel a little better! How long have you owned your h3?
  #25
Old 09-26-2019 | 02:15 PM
Had my 07 for 12 years and sold it this spring about 2 months after I found my 09 Alpha Off Road. So continuously since Feb 07.
  #26
Old 09-26-2019 | 02:20 PM
Ismitty41's Avatar
Well I hooked up the scanner today after i got the motor heated up and it read 218 degrees i just changed the coolant temp sensor gonna see if that helps
  #27
Old 09-26-2019 | 03:35 PM
amrg's Avatar
218 is still fine if thats the max and with a/c. The pressure cap is 14LBs which means coolant (50/50 mix) shouldnt boil before hitting 260* + (not saying you should).
  #28
Old 09-26-2019 | 03:38 PM
Ismitty41's Avatar
I changed the sensor and it is still doing the same thing in just gonna keep driving it and hope for the best i hope its ok
  #29
Old 09-26-2019 | 03:45 PM
Yet, still no pic of your temp gauge?
Your posts are all over the place. Yesterday, @9:18am you posted the ambient temp was 69°F, yet the solus showed 62°F, and there is no way you could lose -7°F ambient temp @194°F ect, it would be more likely for the solus to show plus the actual ambient temp.
Do you own a Hummer?
  #30
Old 09-26-2019 | 03:48 PM
Ismitty41's Avatar
I'm just started it up im gonna let it get hot and send you a picture
