06 H3 abs and traction control lights on
I replaced the CV axle on my neighbor's hummer H3 and now the traction control and abs lights are on. The only thing that I disconnected was the abs wire plug located at the upper control arm. The axle came out nicely and the entire job had no problems.
Whatever, check connector & pins to make sure fully seated. Or you could scan for codes: LF=C0035 & RF=C0040. You didn't post which cv axle you replaced? Bottom line, your cv axle replacement caused damage! **** happens. Now go back and correct!
It was the left side. I've been planning on fixing the problem. This is why I joined this group. I was TRYING to get an idea as to what the problem might be as I'm sure I'm not the only one that this has happened to.
I'll scan for codes once I can get my hands on a scanner. I don't have much experience in this area as I am a BODYMAN by trade. I don't mind trying different things though.
rifsm1
08-21-2012 02:10 PM
BOSS1705
10-16-2008 11:22 PM
