Old 07-14-2022, 01:47 PM
Booch's Avatar
Thought of putting my stock H2 wheels on there , but I wanted to carry one spare for all , At some point I will by some rims and tires that match the H2 but not in cards right now
  #572
Old 07-14-2022, 01:58 PM
I thought about some other wheels but decided on the plain steel ones since they are cheap and it keeps the trailer looking military which was a look I wanted to keep for it. I also converted all the lighting to 12v and replaced the big military lighting connector with a 7 pin one (and a ton of other work on the whole setup). Steelsoldiers forums has a lot of info including technical manuals etc.
  #573
Old 07-14-2022, 02:31 PM
Booch's Avatar
I replaced the bulbs with LED and kept the light buckets, replaced shocks, and also did the 7 pin , Its been a fun adventure
  #574
Old 07-14-2022, 03:42 PM
Originally Posted by Booch
Not really the H2 but he pulls it and they share the same spare, I built an offroad camper over the winter from an M116A3 Military trailer
Off-road camper
Looks cool. Curious what's hanging off the side? Got any more pictures inside?
  #575
Old 07-14-2022, 08:46 PM
Booch's Avatar
That is a 270 deg awning that wraps around the trailer, the other side has an outside shower disguised inside a pelican case
  #576
Old 07-15-2022, 09:33 AM
That is awesome!
  #577
Old 07-15-2022, 09:54 AM
Booch's Avatar
Originally Posted by MixManSC
That is awesome!
  #578
Old 07-17-2022, 11:16 PM
2004H2's Avatar
Default Done Today…
Installed 10 inch slim electric fan, with 30 amp relay to transmission cooler, front of Radiator on H2
2004H2
2006H3
  #579
Old 07-18-2022, 12:26 AM
finall's Avatar
Originally Posted by Sam!
Finally got the transmission cooler upgraded and bypassed the radiator. not a bad upgrade at all.
Would you be so kind and tell me what brand and exact model of cooler you got and where you got it from?
Did it come with all the brackets in the photo, or did you have to make these up?
By any chance, did you do a write-up on this website somewhere?
Like what lines you had to re-route or replace, how you plugged off the now-unused holes in the radiator, how you flushed the old ATF out of the radiator tank so that no cross-contamination was possible, etc.?
I really like your setup, and would like to do the same.
Did you notice any problem with the transmission getting up to operating temp when the weather is freezing or cold?
I ask since that cooler is HUGE.
Do you know if the trany has a thermostat in line with the cooler, to close off the cooling circuit till the temp comes up into proper range?
Any help is much appreciated. Thanks!
  #580
Old 08-14-2022, 07:07 AM
Kiribro's Avatar
Nothing special tho, just a small maintenance routine: cleaned windshield, checked tire pressure and the oil level. Also, bought new back seat cover for dogs.
Quick Reply: What have you done to your h2 today?
