Upgrade to 2008 door panels
I have a 08 H3 and recently added a H3T and neither one has any interior squeaks or rattles.
The newer 08/09 interior has more durable interior panels and materials. Just like all GM vechicles, they do make some noises. The 08 truck seems to be a little more solid over the 07 and older interiors.
Switching to the new door panels may require a dash change to though. Where the door meets the dash looks like it would need changes.
So does anyone know if you can switch to 08 interior in the older model h2's?
I think anything could be done but it wont be cheap or easy. I think you would need the complete dash and wiring harness to make it work. It would be cheaper to trade up to an 08
Did something similar but with a twist. I have a 2008 but door got side swiped, replaced with same color from part out but was pre-2008 year. Found that the door was missing a few holes for the clips to mount to the 2008 door panel Lined them up and drilled then worked like a champ. So you should be able to use a 2008 door pane on a 2003-2007 but just need to drill a few holes to make it work.
This old dawg is now CLOSED.
bradsterdragster
08-10-2012 11:12 PM
koth
07-22-2009 07:48 PM
