Transmission swap
Transmission swap
Would a transmission(9FFD which I believe to be out of a camaro) work on my H2 while the original is being rebuilt? It's lost 3/4 but I need it back on the road ASAP, and being in the UK, parts/rebuilt box's are not readily available
As legerwn mentioned, It's possible but your gonna have to change some parts, the H2 doesn't use a trans with a tail cone and has a short rear shaft that directly fits into the spline on the xfer case. If you interested in trying it check out this video:
