Transmission Hot on display, not towing anything
#21
I found a radiator core support with your layout, that is now in a salvage yard:
Proper airflow is the key to longevity!
#22
Engine temp…
[QUOTE=hummerz;410091]You added another debris sh>t trap collector preventing airflow to the engine! Check temp under the hood while driving.
The electric fan made a huge difference in a/c cooling of the truck, when you first started up and it’s 125 degrees in the cab, cooled down in 2-3 minutes had cold air out the vents, so I’ll be reinstalling those 2 fans again on the condenser, I’m sure it will get plenty of airflow I also bought a dual relay to operate 2 fans that turn off/on at set temperatures….
Rick
2004H2
2006H3
[/QUOTE back in the day, we had straight fans, then we had flex fans, before clutch fans came out, so at idle they sucked in more air than a Kirby vacuum cleaner would, todays fans are different, even at idle my truck pulls a good amount of air even with the new cooler on it, though before I put the new cooler on it, I had installed a electric fan.The electric fan made a huge difference in a/c cooling of the truck, when you first started up and it’s 125 degrees in the cab, cooled down in 2-3 minutes had cold air out the vents, so I’ll be reinstalling those 2 fans again on the condenser, I’m sure it will get plenty of airflow I also bought a dual relay to operate 2 fans that turn off/on at set temperatures….
Rick
2004H2
2006H3
#23
[QUOTE=2004H2;410125]
When I put AC in the 65 Vette and added the condenser in front of the rad, I added a Thin Spal Fan in front of the condenser. So now with the DeWitts dual spal fan rad and the condenser fan I can get the outlet air temp measured with an Auto meter temp gauge at the vent down to 34*
So when I flip on the AC ...three fans come on. That's why I use a Powermaster 140 Amp Alternator. The rad fans pull about 27 Amps each at start up and the about 23 amps running times 2. Plus about 15 Amps on the smaller Spal on the condenser.
You have to take in AMP usage when you add High current stuff.
The electric fan made a huge difference in a/c cooling of the truck, when you first started up and it’s 125 degrees in the cab, cooled down in 2-3 minutes had cold air out the vents, so I’ll be reinstalling those 2 fans again one one the condenser and one on the transmission cooler, I’m sure it will get plenty of airflow I also bought a dual relay to operate 2 fans that turn off/on at set temperatures….
Rick
2004H2
2006H3
[/QUOTE back in the day, we had straight fans, then we had flex fans, before clutch fans came out, so at idle they sucked in more air than a Kirby vacuum cleaner would, todays fans are different, even at idle my truck pulls a good amount of air even with the new cooler on it, though before I put the new cooler on it, I had installed a electric fan.The electric fan made a huge difference in a/c cooling of the truck, when you first started up and it’s 125 degrees in the cab, cooled down in 2-3 minutes had cold air out the vents, so I’ll be reinstalling those 2 fans again one one the condenser and one on the transmission cooler, I’m sure it will get plenty of airflow I also bought a dual relay to operate 2 fans that turn off/on at set temperatures….
Rick
2004H2
2006H3
#24
Rick
2004H2
2006H3
Rick
2004H2
2006H3
#25
Missing the point…
I totally understand your side, being a Tractor/Trailer mechanic for 45 years for a major food company, adding the extra cooler decreases the air flow,yet it makes no difference to the truck at 70-80 mph its ram air, and since it has a brand new aluminum radiator in it, actually put a new aluminum radiator in both hummers,the best way to improve air flow would be to remove the grill,install a custom screen grill and add foam tubes on both ends of radiator between the condenser and the radiator, because air follows the least restrictive area, so if you block off those sides it has a positive air flow….
the H2 is 20 years old, hopefully it will last till I can find a replacement, there’s nothing out there I like….just a bunch of shoe box’s on wheels
Rick
Rick
#26
Thank you
[QUOTE=Mark R;410126]
thanks, each fan draw is 3 amps 7” fans , there’s not a lot of room for fans in the split clam shell hood on the H2, the fans has to be in the condenser side or mounted on the hood side, I’ve tried some bigger fans but the hood crushes them, there pushers……so 7” seems to be the ticket….
Rick
Rick
greg260
08-17-2013 04:28 PM
