Transfer case motor fix
If you push the selector switch on your transfer case selector switch and only the lights flash, your transfer case motor is hung up. 4 bolts hold the motor in place. You can remove those 4 bolts, drop the motor and test it with the motor off. Without being attached to the transfer case, it possibly can free it up. The issue is actually inside the motor. 3 screws hold the cooper coil covering on. Put some grease on the end of the coil shaft that sits in the end of the cover and spray some lube inside the gear housing as well. The motor has dried up and just needs to be lubed. Be sure to watch how you put the coil cover off. There are two springs that will shoot out if not set correctly.
Can't shift out of 4 Low. I removed the trans case motor from the transfer case, used electrical cleaner and then tried to make it move by pushing the buttons while the truck in neutral. Tried this with motor running and also with motor off and accessory on. it makes absolutely no noise. I can try pulling apart but it more likely seems to me it is not receiving power. That possible?
Hope this assists others with similar issues.
igolf2
01-28-2019 12:32 PM
