Torque Specs for 2006 H2 Hummer
HIya,
I am working on the front and rear suspension this weekend. I have searched on the forum and also on the web and can't seem to find specs for below. I purchased the upper control arms, both upper and lower ball joints, and inner and outer tie rods from Kryptonite - I have torque specs for those (they send with the kit).
From a separate vendor I purchased the swaybar end links for the rear.(no lift, all standard OEM). I am trying to find out what the torque specs are for:
- End links to the swaybar,
- front steering damper,
- all four shocks, and
- front lower suspension control arms
Rear end links - 59 lb ft
Front shocks lower bolts - 59 lb ft, top bolts - 15 lb ft
Rear shocks - 85 lb ft
Front lower control arms - nuts - 160 lb ft, lower ball joints - 37 lb ft plus 90 degrees
See attached pdf on the steering shock...
hilarious response
I had to chuckle on the break it replace it comment. I am not a big muscular woman but I know how to use my weight for leverage - unfortunately I can break things........ give for instance a bolt that is supposed to hold solar panels down to a ground mount system for 150mph - so I pulled the bolt through the frame - have to go to the manufacturer on that one.
Thanks again.
hnijhar
10-27-2019 05:15 PM
Kimberly Walters
03-01-2017 08:44 AM
Synthetickiller
08-14-2015 11:15 AM
lostsoul77
03-25-2015 08:41 PM
skicranmore
09-24-2014 08:36 AM
