Replacing fuel tank pressure sensor
Old 09-28-2020, 06:34 PM
Old 10-02-2020, 04:15 PM
2005H2's Avatar
The check engine light hasn't turned off after the repair although some have said it would. I went back to Auto Zone and used the scan tool to manually clear the fault.
I'll be waiting to see if the light comes on again, if it does, I'll replace the fuel cap.
Trouble with this code as we all know is that it could be a variety of things, process of elimination.
Old 10-02-2020, 05:03 PM
What I posted before about it turning off is from the official GM Service system that dealers use but maybe some other code was keeping it on? Hard telling...
Old 10-02-2020, 06:24 PM
could be a rust hole on the top of the fuel pump causing the error.
Old 05-23-2022, 04:09 PM
rswizards's Avatar
Default Question
Originally Posted by 2005H2
Figured it out, super easy fix that took about 15 minutes.
All you need to do is remove the left rear plastic wheel well. Then you'll be able to see the sensor directly and get to it.
This requires "feel" and you'll need to reach in and remove the old sensor. It disconnected easily but had to use a plastic pry tool to remove the old one.
Then I put the new on in place by feel and connected it again by feel; you won't be able to see anything.
Did you remove the tire? Or can you reach it with the wheel on?
miniLinux
08-11-2014 05:58 AM
SwillRacer
01-19-2013 08:11 AM
parabat
04-26-2011 11:44 PM
austoak
02-04-2011 08:53 AM
Stupid Dog
11-30-2008 04:59 PM
Quick Reply: Replacing fuel tank pressure sensor
