Pulled to one side when bracking.
first make sure all four tires are the same pressure
if one tire is worn more then the others it can cause pulling
next you would have to make sure your calipers are not binding and that they float freeley on the caliper pins.
after that then maybe a caliper bleed and or fluid change.
Make sure you test on the flat road. Most roads are crowned, and that naturally causes vehicles to pull to the right a bit, even under normal circumstances.
How many times have I thought that there was something wrong with the vehicle, and it ended up being the road. Unlikely that is your problem, but I thought I would mention it anyway.
katakenm
04-20-2014 04:37 PM
Mr_Fulano
02-06-2013 12:56 PM
