P0300 General Cylinder Misfire
Brothers
Hummer H2 2006 - 50k miles on new engine
The entire story on this engine light coming on and a Code P0300 on my OBD is something that won’t go away. Two mechanics, all plugs, wires, ignition coils, etc changed out. The valve covers removed for inspection and so on.
Yet when I drive for a couple of hours and things get hot, including the weather, I stop and when I restart the engine it throws the code. No specific cylinder code with it. No feeling of anything wrong, everything works fine. My OBD reader is ok but does do what the pro readers do, but I took it to two shops.
i make this same trip each week and when it’s hot out it comes up. Today was raining and in the low 90’s and the code did not appear.
I see its a common problem with Hummers this age. The shops I took the truck to are well respected and the second shop did the swap on my engine a few years ago and they had a team of guys checking it over. They couldn’t find a thing.
Anyone have any similar problems?
Ted
Ted
I drive to a area of Texas where there is not much in the way of Mechanics and when I get back it’s late.
One thought is to upgrade my OBD tester. I use OBDLINK SX. It’s been good for what I need it for but maybe I can pinpoint the problem with a better tester? Any suggestions on how I could test this myself?
Ted
Ted
Ted
Ted
Perform an induction cleaning.(I posted a cheap kit above)
Btw, only use top tier gas!
finall
05-06-2017 08:50 PM
norinco3264
02-09-2015 05:00 AM
azz7772
01-10-2008 10:03 AM
