Hummer H2For those who like a little more gleam to their Hummer, the H2 offers a similar rugged look as the H1, but as a lower cost, and with more added features, making it almost a massive luxury SUV.
How to replace oil pump in my 2003 h2?
Little point for tips or tricks to make the change go smoothly...
Have no oil pressure...
New oil pressure sensor installed...same...
the o-ring that seals the oil pickup tube to the oil pump is notorious for causing your issue. it fails or shrinks letting air in which will not let the pump prime.
Always monitor the engine oil, keep it clean, and only use full syn! In the meantime drop the pan, clean the screen, and as Bronx stated, replace the pickup tube seal. Recheck oil pressure.
