No crank, no start
No crank, no start
Hi. I have a 2005 Hummer H2 , went to the store, came out turn the key nothing, passlock light went out,Battery is full, towed it home sat for two days turn the key to on then to accessory can hear a slow thunk thunk thunk, key wont turn off, key is stuck in accessory position and and cant shift out of park with key in the on position and battery is now dead.
so what a bad ignition switch?
does your cluster actually show you are in park?
reason i ask is because the shift cable bushing on the transmission end goes bad leaving the transmission in whatever gear it popped off at. not in park no key. another probable cause can be the shifter wiring in the center console. the wires tend to break from moving the shifter also causing to not release the key. both very common issues with the H2.
stoneman
05-07-2018 01:41 PM
