New here and need some help.
Location
where did you find this for the 2008? I would like to see it for the 2004….
For most of the Hummers I have seen, the accessories match the level. You have the three trim levels correct. I have attached the spec sheet for the the 2008 Hummer H2. Where you will see variability is the "O" for options that the dealer or customer would be able to add. If you have a year in mind, you will want to check the spec sheet to confirm features and options. For example for air suspension on the 2008 series, it was standard for the Adventure, and an option on the Base and Luxury.
Ah... you are looking at 2004... there were three trim levels: Base, Adventure and Luxury. Here is a copy of the 2004 spec sheet. It mentions the trim levels, but does not show clearly which options are included in which trim level.... but probably not too far off from the 2008 sheet I shared.
Color
The spec sheet don’t have the color the one I’m looking at listed metallic sage green?
Two colors were discontinued mid-year 2004: Metallic Sage Green and Sunset Orange Metallic. So this spec card was probably made after those colors were discontinued as it also includes colors that were part of the 2005 series: Desert Sand and Stealth Gray. This car may have been a late 2004/early 2005 spec sheet.
In 2004, there was a special edition color that does not appear on that card as well: Limited Edition Victory Red
Ok
Ok got ya.
Makes sense… Thanks guys for your help
QUOTE=Brunob00;396814]Two colors were discontinued mid-year 2004: Metallic Sage Green and Sunset Orange Metallic. So this spec card was probably made after those colors were discontinued as it also includes colors that were part of the 2005 series: Desert Sand and Stealth Gray. This car may have been a late 2004/early 2005 spec sheet.
In 2004, there was a special edition color that does not appear on that card as well: Limited Edition Victory Red[/QUOTE]
Xtreme
12-08-2006 01:53 PM
