New gear box on 2006 H2 - noise
Hi there,
I have had some work done on my truck 2006 H2 (mileage is around 66k)- I purchased Kryptonite upper control arms, upper and lower ball joints, inner and outer tie rods and center link, also idler and pitman arm. The mechanic said I needed a new gearbox so I had that replaced with a RedHead. I expect the truck to drive and feel more tightly in the suspension through to steering.
On driving home after the gearbox was replaced on slight turns I could hear almost a chaffing sound - the same sound if driving on sand that comes from braking slightly - as the brake pad hits the rotor. In the past I had the powersteering pump replaced so I should be good there (when I dropped the truck off the powersteering worked well). Turning the wheels is also much harder - almost as if the power steering is failing.
Is it normal when a gearbox is replaced to hear a slight chaffing sound on slight turns and stiffer steering? The guy that did the work is not my regular mechanic at the shop who did previous work so I am a bit concerned that he may have done something incorrectly or affected the power steering in some manner.
Any advice/comments would be greatly appreciated.
My redhead box has been nothing but a pain in the butt. I think they just require more fluid/pressure than stock. It also takes a while to bleed out all the air in the system, no matter what you do. Most replacement ps pumps come with the wrong orfice valve for trucks. I have a post on here somewhere explaining all of that. When I replaced my valve, it did make a difference but was still not good enough.
I'm in the middle of a new engine install now but along with that I upgraded my power steering pump to a 12 vane unit, I've read this is the cure. I'll let you know once I get the new engine up and running.
Tim
Tim
