Need top level wiring diagram for 2005 H2 SUT - Power locks
I need the wiring diagram for a rear driver door lock. Basically, I was adding new LEDs to my power windows and lock buttons. Took door panel off for the rear driver side, and replaced LED in window module. Put back together and the power door lock wont work. I am not sure if this has been an issue in past or not, but it definitely not working now. So I figured it was the power door lock assembly, so I purchased new one. replaced, and door lock still doesn't work. Thought I was crazy so i removed the passenger rear door module, which I know has functioning wiring harness and locking mechanism. replaced with the new passenger one, and it still doesn't work. Long story short, I realized that both the driver and passenger rear door locks has a 6 wire connector and that only 4 of the pins are used, also, one is the inverse of the other, since they are on different sides, but the 4 of 6 pins are different also, so I cannot use this as test. I am down to I either bought a door module that is broken from factory, or I have a wiring problem, and my original door mechanism is still functional also. Not sure how to test, and wanting to trace down wires, but first want diagram to make sure that there could not be the possibility I messed something up in the window controller that is affecting the locking mechanism. Does this make any freaking sense? I tried to explain the best I could. Either way, is there a repository for wiring diagrams on this site, or anyone have link to another site to look for them? Thanks in advance!
cjmilto
07-24-2014 10:07 AM
jhpulley
11-27-2010 12:21 AM
