Need Help
Old 02-26-2011 | 11:52 PM
dougie's Avatar
Default Need Help
I need help. Nothing electric works on the front passenger door on my 2003 H2 from the switches on the front passenger door or the drivers door. The remote does not either lock or unlock the vehicle. I have looked at the fuses at both the engine and under the dash but cannot see anything wrong. Can anyone suggest what could be wrong? Please send any info to daewylie@gmail.com
Old 02-27-2011 | 01:15 AM
Tech5's Avatar
any check engine lights?
have you checked fuel pressure ?
Got gas in the tank? Sure your gas gauge is correct
Old 02-27-2011 | 03:26 AM
dougie's Avatar
I haven't noticed any check engine warning light.
I put about 5 galls gas in tank to make sure. Not sure how to check gas pressure.
A Hummer dealer said the inboard computer needs to be reset.
Old 02-27-2011 | 11:40 AM
dougie's Avatar
another dealer said the computer didn't need reset. It might be the fuel pump and wanted to drop the tank. Have you any other ideas?
Old 02-27-2011 | 03:59 PM
luda81's Avatar
dude check you fuel injectors. remove one of the injectors and have some one crank the car to see if fuel is coming out. I bet it is the fuel pump. if not fuel pump it is probably related to fuel pressure. Dude this is not a big problem. and yes you will have to drop the tank to check fuel pump.
Old 02-27-2011 | 04:06 PM
luda81's Avatar
Hey forget my last post. this is much easier way to check pump. Remove the fuel pump relay. its is probably in the under hood fuse box. Then crank the car till all it does is crank and not start. Then put the relay back in and crank the car. See if it starts. if all it does is crank the fuel pump is bad.
Old 03-06-2011 | 05:40 PM
dougie's Avatar
Default Starting problems on a 2003 h2
The mechanic dropped the tank , put the new fuel pump in,engine started immediately and has been running perfect now for 3 days. The old pump came with the vehicle some 105,000 miles ago. The dealer wanted $780 for a new pump-we purchased one on line from Parts Geek in New Jersey for $179.
Many thanks to all who gave suggestions to me problem.
Regards,
Doug
Old 03-18-2013 | 04:41 PM
rayray's Avatar
Default engine stalls need help
H2 hummer keeps stalling
I changed my fuel filter listened to my fuel pump its running does anyone know what the problem is
also my A/C wont work I had it checked out its charged and there's no leaks
it runs if the ac repair man jumps it with a wire but he couldn't figure it out
importkiller
29
01-15-2008 03:51 AM
WOLFGANGSTA
02-11-2007 04:55 PM
crc2k
09-01-2006 05:03 PM
skeeet
03-16-2006 06:21 AM
efrainl956
05-16-2005 11:46 PM
