My 2007 h2
#361
I thought about going the homemade vehicle route but you are not allowed to modify an existing vehicle. I don't understand how these rat roach rod things are legal to go down the highway. Some I’ve seen at car shows belong in the dumpster. Totally unsafe.
#362
looking good,
A buddy of mine rode with me when I was looking at a H2 on a lot to purchase prior to purchasing the one I have now but unfortunately they had to send it back as the millage had been tampered with. While looking there they had a HUMVEE sitting there and my buddy purchased it, its a 4 man 91 I believe with the 10,500 axles. I've been working on it for him fixing little things that it needs, he drives it to work and around town he loves it. They are neat trucks with unbelievable capabilities off road, right now I'm in the middle of installing a Red Dot AC unit which is the original units built for the gov to install in the trucks. The 24 volt system on these trucks causes a few issues when adding accessories along with the simple task of jump starting the thing.
Keep us posted,
Neal
Keep us posted,
Neal
#363
Back to working on my H2 again. It’s been a great vehicle to own. I’m trying to figure out my ac out of the defrost vent. I tried resetting it twice but it didn’t seem to work. I believe it has a bad actuator, the one on the drivers side above the gas pedal. I did have a dead battery and I thought the reset would fix it. I’m getting ready to finally start my electric fan conversion if I can find all of the parts that I have had for several years. lol
#366
Finally installed my electric fans, only took me 2 or 3 years to start it. I had a new gm fan assembly and it’s the 7/9 blade set. I had to take a little bit off the bottom corners and cut the flange off top and bottom. I have the oversized BeCool radiator and I think it made it difference in fit. I had to drill 2 holes in the radiator support so I could mount it. I used 3/4” dense foam to fill the gap. I installed oil lines for a 2008 H2 and they fit perfectly with the fan set. I also got a 2008 fuse box cover and it has the extra compartment for the new relays. I used a harness from BP and it seemed to have heavier wire and it’s very well made and great instructions with pictures… I had to pin 2 wires in ecu plug but it was fairly easy to do. Took it for a test drive and ac has never worked better at a standstill. I might be making things up but it felt like it takes off better. I was really tempted to add a cam but I didn’t want to pull radiator out. I am very happy with the outcome and I wish I would’ve done it sooner. I will try to add some pics later.
Mr. Fancy Pants
08-22-2010 09:05 PM
REDLYNER
30
04-18-2008 08:40 PM
