Low Oil Pressure?
Low Oil Pressure?
i’m getting about 18-20 at idle, and 38-40 at WOT at 5,000rpm. what could be causing this? i do have an oil leak but nothing substantial. it’s on the passenger side, aswell as i noticed around oil pan. could it be oil pressure sensor? oil pump? clogged pickup tube? i have put lucas stop leak in it about 2,000 miles ago. bought it at 180k and have no clue what previous owner has ran/used before i got it. oil level is one dot low on stick from full, just added .25 and it didn’t help pressure at all. it even safe to still dive it? low oil pressure light hasn’t come on but its been making me nervous. don’t really wanna get rid of it, nothing else like it at all. should i be looking around for a new motor?
Is this at hot idle like after a run on the highway or hard driving? What’s it like at cold starts. This is still well within gm spec. You should be worried when you start seeing under 10. What viscosity of oil are you running? What is the ambient temp like at the time of the photo?
My point being, the first time I saw 20Lbs I almost dropped a Brick from the back end of my shorts! After reading the owners manual on the 502, it stated that you should not be worried about the 20Lbs at idol. This is normal for the 502....partly due to the cam and stoked crankshaft.
There are items as Gavin has mentioned that are causing that reading. My first guess would be the sender. Also I would be running a Good oil. As far as what weight to use with your high milage rig.... I'd wait to see what is suggested my your fellow same year owners.
Those little pesky motors talk to me when I open the door and get in my 2. I can here them doing something in the back round. Not mainly from the dash but somewhere near the center NAV display.
ferraribuyer
03-27-2017 09:04 AM
