Loud front end clunk at hade acceleration
I have 2007 H2 with 250K miles and have a loud front end clunk at hade acceleration. Only heard from a stop. Occurs in high and low gear. Changed transfer case fluid appears normal. No adverse sound at all while driving. Could the front u-joints cause this? Any suggestions much appreciated. Also had the upper and lower ball joints replaced a while back.
Well it has been about a week since then and not only has the noise gotten worse but the car has also developed a very nasty sounding clunk while accelerating as well. Im really unsure of what to even be looking for at this point because every time I look under the car everything feels solid and nothing looks broken or loose at all.
All H2 questions go in the H2 section so that other H2 owners might be able to help.
Front end clunk
Just saw this, but I was having the same problem. Turned out the front differential bolts were loose. Replaced 3 bolts and no more clunk. The main bolt that was causing it was right next to the oil filter
Unbelievable.
