Looking for LED Headlight/Fog light
Old 08-31-2018, 04:41 AM
Qwelin's Avatar
I was thinking about getting the LED “bulbs” for the standard housing but didn’t want to be “that guy” on the road at night. I ended up getting a set of Philips +100’s. I had the +80’s on my JK and it made a HUGE difference, so I figured these new +100’s would be even better, especially since the JL halogens are actually good, to begin with. Totally shocked and impressed with how good they look. A MUCH more full and bright low beam, and high beams that look like the old KC Daylighter driving beams https://10carbest.com/best-jeep-wrangler-led-headlights I had on my JK. So good in fact, that I’m thinking about omitting a set of off-road driving beams and just adding a set of Rigid side shooter Hyperspots by themselves and calling it good.
The Philips +80 and +100’s (now called extreme vision I think) have filaments that are more tightly wound, smaller gauge, and slightly longer to reshape light output. Still the DOT legal wattage and lumen output. I did have to re-aim the lenses though (as I did with the JK) since the beam is more intense and projects out a bit further. A couple twists down is all it took, and now the low beam pattern is noticeably more intense with no hot/ dead spots, and projects down the road a bit further with a well defined cut off and no glare/ scatter.
Old 09-08-2018, 08:18 PM
jsbihn's Avatar
FYI, the 4 inch foggies do fit, but are way small.
basically when you put them in, be prepared for a gap
hummer_on_fumes
08-07-2020 07:26 AM
accely
11-26-2019 10:07 AM
surfcityred327
04-15-2018 09:10 AM
H22003
21
12-14-2017 12:47 PM
bosoxdew
09-08-2012 07:43 AM
Quick Reply: Looking for LED Headlight/Fog light
