LED Scuff Plates
LED Scuff Plates
Ok, I have a 06 H2 and I知 trying to install LED scuff plates I ordered for the front doors. Because of where I live and the pandemic I知 unable to get a professional to do it. I got everything I need off the one YouTube video of someone installing them on an H2 but for some reason they never specify which color wire they are splicing into for the dome light. I got a test light and confirmed it works but it seems like I致e tested every wire in the wire bundle I知 supposed to with no luck. I know this post is a long shot but I知 at the end of my rope trying to figure it out. If anyone can help it would be greatly appreciated.
Thank
this looks like exactly what I need although it is pretty blurry. Going to try and print it out see if it helps. Thank you I really appreciate it.
What I think you want is the power wires to the B pillar courtesy lamps. That seems like that would be the easiest and closest wires to access for that. There is a light down low near the floor there and could be used for both the front and rear sill plates (if it is a set of 4). Those wires (on both sides and also for the rear door courtesy lamps) is grey/black (positive) and black (negative).
Sigh
Not sure if any other wiring is right there where those lights are. The schematics just say solid black is negative and the grey/black is positive. I'd assume there might be more than one black since the same wires feed the courtesy lights in the rear doors too.
in the YouTube video I watched the guy grounded to one of the wires in this bunch. I truly appreciate you taking the time out to help
Yep, that was my thinking. Those B pillar lights are down pretty low on the pillar so should be able to maybe pop the bottom of one edge out some to get at the wires to the light. That way you know 100% you have the right ones. There can be a lot of things that use the exact same color wires for different functions.
Hummer2006h3
08-11-2017 10:25 PM
atari800
08-31-2015 06:10 PM
oceanbrave
06-16-2015 03:14 AM
