Leaking "Something"
Old 06-19-2023, 07:22 PM
jhall's Avatar
Default Leaking "Something"
so i have something leaking and it is landing on top of my front diff crossmember mount....has the entire mount soaked...it appears to be clear in color and no smell....i only assume it's power steering fluid but i cant get under it right now cause it's pouring rain here and will be for most of this week.....just wondering if anyone has had the same problem and am i on the right track with my assumption
thank you
jody
Old 06-19-2023, 07:42 PM
thank you
jody
"clear in color and no smell"=H2O
Old 06-20-2023, 08:07 AM
calif phil's Avatar
If it is a pretty good leak, the power steering should be emitting a whining noise if low on fluid. It the coolant level low?
Old 06-20-2023, 12:20 PM
finall's Avatar
This is typically power steering fluid. It is exactly located in that area, and drips down from the hoses. Common problem on the H2
It does not take much fluid to wet the area, but you should be seeing a drop in the PS reservoir.
Old 06-20-2023, 04:01 PM
Old 06-21-2023, 02:22 AM
Lifted37's's Avatar
Default something leaking
It may be coolant leaking too, check your coolant
Old 06-21-2023, 05:43 PM
finall's Avatar
Unless you are running pure water, coolant is not clear like OP is seeing. Typically GM Dex-cool pink, but some may have switched to generic green.
OP did not tell us if the goo is water soluble or not. If it is, it could only be coolant or brake fluid or ww fluid.
Old 06-21-2023, 06:45 PM
European pink or Asian pink?
DEX-COOL is ORANGE, same color as the cap!
Old 06-22-2023, 04:14 PM
finall's Avatar
Nope, pink. Read thread to understand.
https://www.camaro6.com/forums/showt...%20concentrate.
And I do not run pre-mixed, as I prefer to run 60/40, as it offers superior cooling. I am not trying to save pennies….
Old 06-22-2023, 04:38 PM
Some1 f'd up & added the wrong coolant.
Prestone manufacturers ACDelco / GM Original Equipment Dex-Cool & it's still ORANGE!
Quick Reply: Leaking "Something"
