I need your help
Old 02-12-2021, 10:49 AM
hmer's Avatar
plenty of room for batteries once you pull all the ICE needs. you have the whole engine bay and most of the underside of the chassis. depending on what drive system he chooses. can always also do a body lift to gain more vertical space down there. Or add a hard case cargo carrier on the roof
so yes a body lift was already advised last night by a engineer . even without a lift the gas tank area and engine compartment can store some tesla cells . but the best setup is the body lift .
Old 02-12-2021, 12:21 PM
yes do not forget all the room not having the exhaust system will save as well. plus the area behind the tow hitch. plus as i mentioned you have the roof as well. up to i think 350 pound payload. you can make even more room if you use direct powered wheels. then no need for any of the drivetrain. no transmission no transfer case no axels. but would probably need to convert the rear axel to independent suspension. something like this E-Car Hub Motor | qs-motor.com
Old 02-12-2021, 06:23 PM
Originally Posted by hmer
here is the deal the entire point of this build is just for A FUN project not trying to be the next Elon . as of today I now know theres plenty of options to mount a battery up front . (engine bay area ) .
Check out EvWest.
Old 02-13-2021, 12:34 AM
hmer's Avatar
thanks . yes i had been watching this channel for some time now .
john1961
07-20-2020 03:21 PM
KA H2
09-23-2012 02:54 PM
rsmith77
31
04-18-2012 07:30 AM
2wheelmonster
22
06-14-2010 10:07 AM
GHummer
32
09-16-2006 08:29 PM
Quick Reply: I need your help
