Hummer h2
Old 10-19-2021 | 03:57 PM
https://www.kolhosniki.ru/mitchell
thats a link to mitchell on demand. the main site has links to other softwares for european makers also.
  #32
Old 10-19-2021 | 05:23 PM
oceanbrave's Avatar
That could be the fuel pressure test port, never had to go there.
This is the GM tester J 34730-1A, it looks like it would fit there
and here is a snippet from the GM manual showing the hook-up albeit it's a poor diagram:-
The pipes don't look like yours, but the connector does and I would imagine pressing the pin would release fuel under certain conditions, quote:-
"Caution: Wrap a shop towel around the fuel pressure connection in order to reduce the risk of fire and personal injury. The towel will absorb any fuel leakage that occurs during the connection of the fuel pressure gage. Place the towel in an approved container when the connection of the fuel pressure gage is complete.
Notice: Clean all of the following areas before performing any disconnections in order to avoid possible contamination in the system:
• The fuel pipe connections
• The hose connections
• The areas surrounding the connections
Install the fuel pressure gage to the fuel pressure service connection, located on the fuel rail.
Turn ON the ignition.
Caution: Do not drain the fuel into an open container. Never store the fuel in an open container due to the possibility of a fire or an explosion.
Place the bleed hose of the fuel pressure gage into an approved gasoline container.
Open the bleed valve on the fuel pressure gage in order to bleed the air from the fuel pressure gage.
Command the fuel pump ON with a scan tool.
Close the bleed valve on the fuel pressure gage.
Inspect for fuel leaks"
  #33
Old 10-20-2021 | 07:50 AM
calif phil's Avatar
Originally Posted by chevykev
Just another thought, should fuel flow from here with key on and pressing pin ? ( it doesn't) not had chance to do much else yet.
It will only have fuel pressure for an initial 2 second prime or fuel pressure while cranking. Key On Engine off will not have pressure after the initial 2 seconds.
  #34
Old 10-25-2021 | 03:39 PM
chevykev's Avatar
Got most of alarm removed, no change, engine will start, run rough / lumpy ,backfire, run fast on its own eventually cutting out. No codes showing up. Someone said could be crankshaft sensor so got one on order.
  #35
Old 10-25-2021 | 05:48 PM
disconnect the MAF sensor plug and see if issue improves if it does the MAF is dirty or faulty.
  #36
Old 10-25-2021 | 06:04 PM
H2-SUT's Avatar
Chevykev, glad to hear you got most of the alarm out. Soon you can concentrate on the engine issues.
What Bronxteck suggested is a good idea, Electrical issues/bad MAF can cause all kinds of crazy issues. The Crank sensor usually cause no start issues but perhaps yours is on the verge of just crapping out completely. While you down there check the connector to see if its clean and making good contact. Do you have access to a high end OBD2 tool that can do a trigger crank sensor relearn? If you have a buddy with a tech2 its a few minute job. GM will charge you about $85 if you can't do it yourself.
  #37
Old 11-02-2021 | 05:55 AM
chevykev's Avatar
Looks like it was MAF sensor took it out, cleaned it all seems good ! Removed all the alarm , seems to have cured battery drain. Thank you everyone for your help
  #38
Old 11-02-2021 | 11:18 AM
H2-SUT's Avatar
ChevyKev, Fantastic, You've gotta love it when a plan comes together especially when you get in there and do it yourself. I was a little worried when I saw that rats nest of alarm wiring. No easy feat to pull those out and have everything work!
Congrats again on your accomplishment!
  #39
Old 11-03-2021 | 09:24 AM
oceanbrave's Avatar
chevykev
Good job!
marine60
04-22-2015 07:45 PM
David Stanley
11-05-2014 03:12 AM
toad
11-25-2013 10:13 PM
Cruize
09-20-2013 12:06 AM
andreigeorgescu86
01-04-2011 01:45 PM
Quick Reply: Hummer h2
