HELP! Key stuck in 2008 H2 ignition
so then you have to check the shift interlock solenoid in the steering column to see if it gets powered on parking or neutral and if it does function correctly then check the key cylinder for binding. you can release the cylinder from the housing to inspect and clean. just be careful of the lock pins they can fall out if not careful.
