Heavy Duty rear hatch supports?
I've gone through 2 sets of rear lift supports for my rear hatch in over 2 years. Is there any such thing as heavy duty that will last more than a couple years especially in the winter? What a joke these all are. May have to figure out a way to transplant the Escalade electric rear lift, now that would be cool.
Yes there are. There are a couple of threads on here that have part numbers for some heavy duty ones. I put some on mine a few years ago when I had dual rear ladders installed. Do a search and dig through some threads on here and you should find them.
Found several threads, this seems to be what I'm looking for. I don't have the weight of the extra ladders, but I did use the rubber with foil sound deadener on the inside and outside of the rear tailgate metal, lots of it, so there is a weight issue.
Not only that, I just hate crap that doesn't work.
Thanks again sir.
Gobi has several aftermarket options for the H2... they have a set of heavy duty gas shocks to be installed after you add their ladder... may do the trick...
https://www.gobiracks.com/product/re...ent-hummer-h2/
justanotherhemi
27
11-18-2012 06:59 AM
red92901
06-20-2010 06:07 PM
