H2 tire carrier pin replacement-
Hi All,
Since years are passing and the wire cable that holds the safety catch pin can age, fray, break etc.. I thought I would make this post to save you hours from searching for a pin & lead to attach it to the carrier latch...
Here is the pin on amazon that is near exact (other than being anodized) - works perfectly as a replacement - Monroe Hardware LBR-SS7109 1/4 X .75 17-4 Button Rapid Release PIN
For the leader, if you have the ability to crimp you can make one, If not here is a suggestion that doesnt involve crimping or buying cabling, etc-
135# musky fish leaders in a 8" (possibly a 6") length- you can get in a pack of 3 and use 2 of the stay lock snaps (one on each side) to pass through the hole on the carrier and the new pin. I doubled mine up - 2 leaders under one snap lock.
https://www.ebay.com/itm/121615393538
If anyone else has a source for the oem part I would love to see it- Just posting to save others hours of search to find the exact push pin for the carrier...
Chris
https://www.amazon.com/Monroe-Hardware-LBR-SS7109-BUTTON-RELEASE/dp/B01HTZ2MAE/ref=sr_1_1?keywords=Monroe+Hardware+LBR-SS7109+1%2F4+X+.75+17-4+Button+Rapid+Release+PIN&qid=1580152664&sr=8-1
Chris
Glad it helped!! Pin still works perfect after 4 years. If anyone ever finds an oem solution - post it!
Amazon shows not available - did it quick search and this may be the same part. https://www.grainger.com/product/Quick-Release-Pin-Button-Handle-410K10
let us know how you make out.
markdoddridge
16
04-27-2015 07:03 AM
