h2 steering issue
Old 12-06-2022, 08:22 PM
finall's Avatar
Originally Posted by MixManSC
I'd as other mentioned use what the owners manual calls for or something like the Prestone shown above since it specifically states for American vehicles.
So here we have a trust issue problem. The OP showed us a link to the Kroon oils website, which is clearly wrong in recommending ATF use in the 2007 H2. So we do not trust Kroon.
So why should one trust Prestone (a brand that I have not trusted but had to use in the 1970's as there were few options then).
I do not. Clearly I only trust GM-approved stuff. And that would be AC Delco. Because there have been enough issues just using GM products (c.f. the multiple transaxle fluid spec changes for the C7 Corvette due to slippage), without introducing other variables like different manufacturer blends.
Yes, ATF can work just about anywhere in a pinch. You can use it as gear oil for short periods too in things like differentials. But that is only for emergency situations, like when you need to get yourself out from the backcountry. No other valid reason. And that is my stance
  #42
Old 12-07-2022, 08:28 AM
89021184 REPLACED WITH 19329450
GM assembles - ACDelco distributes - Exxon Mobil(MSDS 30107519) Manufactures 19329450
  #43
Old 12-07-2022, 12:41 PM
wheelieman's Avatar
neal, thx i will do that tommorow. i order acdelco fluid and it will be oke.
i will let you guys know if its fixed
thx again, to all
  #44
Old 12-07-2022, 01:09 PM
wheelieman's Avatar
to be clear, i did order this version from acdelco
19329450 acdelco.
so that will be oke
  #45
Old 12-07-2022, 01:19 PM
legerwn's Avatar
keep us posted on your progress,
Neal
  #46
Old 12-07-2022, 02:01 PM
finall's Avatar
I am told that the Canada version is for colder climate. It is apparently thinner than the USA stuff, but not sure that is true, or if it is all the same stuff, with different country code only.
Maybe someone else knows?
The Canadian # 89061186 (which has now changed to 19329449 (1L size) and 19329451 (500ml).
Not sure how cold it gets in NL.
AC Delco also has a "Cold-Climate" version for where temperatures hit -20F (-30C), which is lighter and eliminates squeel in cold temperatures.
But most of Canada regularly gets that cold, but uses the Canadian version, not cold-climate version.
  #47
Old 12-07-2022, 02:30 PM
Btw, Prestone manufactures DEXCOOL for GM/ACDelco.
SDS705
Prestone AS264 Full-Synthetic Power Steering Fluid for American Vehicles Designed for excellent operation in extreme low and high temperatures (-40F to 266F)
  #48
Old 12-07-2022, 03:35 PM
finall's Avatar
@hummerz
Someone manufactures all fluids for GM> GM does not manufacture fluids. Nor most other parts.
They assemble vehicles.
  #49
Old 12-07-2022, 07:42 PM
@hummerz
  #50
Old 12-11-2022, 12:57 AM
Gavin Costigan's Avatar
In all honesty what I can see in the video is what looks like a worn out steering or suspension component after the steering box. I’d have it inspected by someone reputable that can put it on a 2 post lift and check tie rod ends, pitman and idler arms, wheel bearings, sway bar links and all of the suspension stuff.
A video of your actual truck might help as well.
Quick Reply: h2 steering issue
