H2 Interior Fuse Block Replacement
I have to replace the interior fuse block (left side of dash). From looking at the replacement it would appear that i only need to remove the two connectors (left side of block), pinch the top and bottom release tabs of the block and pull it out to access the screw that holds the rear main connector on, then remove the rear connector. Anyone that has removed this block know if this plan is feasible or will I have to remove the dash pieces to actually get it out? TIA for any advice.
Job Done
Ok, hadn't gotten any responses but got some time and went at it. To answer my own question, NO. Left side dash cowling and knee cowl have to come out, along with the headlights switch assembly. And it didn't come out far enough to get a wrench on the rear connector. Had to attack that from above within extender and swivel. Apparently a PO had someone in there before to install a defunct security/remote start system (all removed 1st week of my ownership) and they never put the fuse block back all the way into the framing clips which explained why I had to hold it when removing fuses from the original unit. Anyway, all done, locked back in and everything work with no loss of power to the PDM. Have yet to disassemble the original to see why it crapped out.
Yeah, it's weird. Pull the fuse for PDM and get continuity between the fuse pins and backside connector pins. Push the fuse in all the way and it loses continuity from the fuse to output pin on the rear connector side. Unfortunately it appears that I have to destroy the center metal pin/connector socket to get a look inside to see just what is happening. I may get to that and will post pics of findings. Not sure if it's a PCB or actual wiring inside.
Andrew Tebbano
08-05-2023 12:11 PM
JerseyJoe
07-20-2017 12:08 PM
