H2 Fuel Tank / Fuel Pump
#21
Nope, I thought that too, but it's definitely not leaking from the end of the clamped rubber fill hose; it's leaking at the base of the filler neck integral to the fuel tank.
#25
The 05 tanks are seriously well made, can't imagine what would necessitate changing one other than damage. Also the complex array of evap pipes etc would seems to negate using anything other than the correct fuel tank, and would introduce too many unknowns, think the FPM is different too.
#26
Our side the the fuel tank filter
understanding is only 2003 models have an externally accessible fuel filter. All later models just have a screen as part of the fuel pump itself.[/QUOTE]
oust[QUOTE][QUOTE]
Where is the filter located on the 2003 Hummer H2 outside the tank?
oust[QUOTE][QUOTE]
#27
Yes, outside of the tank, right at the front of the tank. You can get to it from underneath fairly easily. I replaced mine and it only took 5 minutes.
https://nemigaparts.com/cat_spares/e...n/03/tn03-005/
#29
Savage, thanks for sharing and posting those great pictures, with all the other feedback others have responded with this should make the job a bit more reasonable to do!
A side note, not surprised GM cheaped out and saved $1 not putting in an external fuel filters on the later models...
#30
94H1Wagon
04-11-2011 11:50 AM
