H2 Front axle destroyed
The ring and pinion shop said the whole thing is junk. Find them another one to rebuild. Don't drive your truck around with the transfer case in 4H Locked boys and girls. What is different about the 2008-2009 front axles from my 2005? Compatibility seems to be 2003-2007.
You are correct. I went ahead and picked up the 2009. It has 3.73 gear versus the 4.10 in my 2005. I can't see any external differences outside of the case is cast with a different part number.
Just to close this out. The years are interchangeable if you match the gear ratio (replace ring and pinion). The innerds are different so you can't mix and match components like axles or carriers.
hrcentury21
12-07-2015 12:06 PM
