Front LED signal lights.
I did, it didn't change anything. Does anything else have these same led lights? I'm starting to wonder if they just aren't capable of working as the factory ones did. With headlights on they work as only marker lights. WIth headlights off they work as signal properly. Thanks for reply.
Same problem
I've got the same ones, I'm having the same problem... Won't blink properly even with resistors. I really think mine are wired wrong internally. I bench them and they seem to work right but won't work in the truck. I think I'm sending mine back.
I've had those LED signals for years and never had an issue. I also have LED tails which aside from the opposite blink of the lower bumper lights everything works fine with only the added resistor which was included with the tails. Maybe the LED DRL's have something to do with it?
