External Tire Carrier - A few questions
I have a 2005 H2 and moved my spare to an external carrier I bought off of Craigs List. It appears to be an OEM product. But I noticed there is a bolt hole without a corresponding hole & nut in the bumper (see attached image). Any of you guys have the same carrier and is there a bolt?
I have removed the internal tire carrier. But in doing so, I do not know where the tire jack gets stored. Where does it go?
The guy I bought the tire carrier from said there is a pigtail under the bumper for the light the license plate holder plugs into it. I cannot find it. Am I looking in the wrong place? Is there a better alternative than using the license place holder that is on the tire rack?
Just fitted the same.
I used the wiring instructions for another carrier for the liscense plate lamp.
this has the info (http://www.premierhummer.com/spare_t...tructions.html)
in regards to the 3rd bolt. I lined it all up and drilled a hole and bolted through. Have the same issue with the jack but currently have not removed the internal carrier so this is not an issue.
@Vegaguy - I realize this thread is now about 11 years old, but I recently purchased an OEM external swing arm carrier for my 2005 H2 and have the same situation with the extra bolt hole on the passenger/hinge side of the carrier. My question is, did you have any stability issues with only 2 mounting bolts instead of 3?
Thanks,
Larry
Thanks,
Larry
Bolt Size
Hi guys,
im glad I found this forum. I literally had my 2008 H2 delivered yesterday. I too have the 3rd bolt question. However a bit different. I have the hole predrilled in my bumper. Does anyone know the bolt Size or GM part number for the bolt?
Random-Hero-
04-02-2017 06:49 PM
