Engine "shakes" every once in a while
Hi everyone,
my 2005 H2's engine acts up occasionally and the RPM collapses for a split second so that the whole car shakes a little as if you rode over a small bump. It happens around 1300 and 2000 RPM.
When I bought the car I interpreted it as road bumps so it is not that noticeable. I just happened to look closer as the check engine light lit up on my way home. The error memory says P0332 and P0327 which means that both knock sensors have low voltage. However, the mechanic said it was almost impossible that both knock sensors break.
I would really appreciate your help!
amyandmark3
30
12-08-2012 04:28 AM
Perantes
11-12-2011 03:27 PM
chsnprodigy
04-07-2007 02:35 PM
