Engine low Oil pressure at idle
Hello to all and thank you for your help. I have been able to do incredible work over the years by merely reading and searching the forum, this is my first post, I am desperate. Thank you for all of the post over the years.
I have an 03 H2 (my 5th one). I am getting a very loud noise that sound like the engine is struggling from a dead stop, it is 10 times louder than and the same noise when using Air con. Oil pressure is very low at idle and quickly jumps up when I accelerate. I have blown the upper oil line on my radiator 3 times when I get on it (Upgraded to B Cool High performance Aluminium Radiator and added a high performance trans cooler to avoid the pink milkshake (again).
I have changed all the belts, all the tensioners, all the pullys, the oil filter, the oil, the oil sending unit, oil line. I also seem to have a drop in my power even though she is a beast with road rhino front end and rubber duck brush guard.
Is it my Oil pump? I do hope not, the engine has 180K on it with factory oil pump.
I have no check engine light and no codes.
Thanks to all.
CB
Thanks to all.
CB
Ethanhunt
08-20-2019 08:09 AM
ferraribuyer
03-27-2017 09:04 AM
