Ding sound after keys removed
Hey guys, driving me a bit nuts here.
brought in the H2 to have the heater core replaced, whole dash removed…
now that I have it back I’m running into two super annoying issues that I’ve never seen before.
1. when I take the keys out and open the door, it dings like I’ve left my lights on or the truck in the ACC position, confirmed 100x that lights aren’t on and key is all the way back…
2. when driving over a gravel road on the way home, 3-4 times half the gauge cluster just died on me, always the right side, some error lights, right gauges go to 0… but then after another bump, it turns back on.
both these issues don’t seem to affect anything other than the gauges or the annoying sound, but would like to go back to the mechanic and have him figure out the issue..
does anyone have any ideas?
BWTFDIK
hummerbaja sounds odd and very unlucky.
not saying it's unrelated to the job, however consider this:-
It's easy to try the fuses, that may answer some of the problems, please keep us posted ✔️
- Re the cluster, I'm not aware of it being wired in "2 halves" all gauges are controlled via a single serial data bus, so it's odd for just one side to stop working. It could be a dry joint or fractured track on the cluster PCB, or possibly a loose/bad ground. A fault in the data bus would normally affect everything on the dash, so would seem to be the cluster itself.
- the ding may be related to the Retained Accessory Power being kept alive via something "feeding back" into the wiring, one notorious candidate is the front windshield motor, you can prove this by pulling out the fuses - WS WPR (25Amp IP Fuse block lower LHS of dash) and the W/S WASH (15 amp engine compartment) If the ding goes away it's the wiper motor.
I’m with hummerz. Take it back. If it’s happened basically right after, it’s 99% probable its the mechanics fault. It’s possible he dropped the cluster or something, or there is a loose connection. That’s not something fun to repair on your own even if you like working on cars, electrical gremlins are a big f-no for me if I don’t have to mess with em, I won’t.
miltonluban
08-11-2016 12:34 PM
Kimmea
08-29-2012 08:19 AM
Chameleon
03-09-2009 08:20 PM
