diff and transfer case fluid change
hey guys! i have a 2003 hummer h2, looking to change the front diff, rear diff, and transfer case fluid.
i see that the front and rear diff are 75w90 synthetic. So im thinking about using amsoil severe gear 75w90 for both.
also the t case seems to be a borgwarner 4484? seems like the recommended fluid is Dexron III NOT VI.
1. is severe gear fine for the diffs? or does hummer recommend gm fluids
2. do i need to add any ls additive in the diff fluid?
3. amsoil dexron iii is good for the t case? or use gm fluid?
its either between amsoil or royal purple for me!!! amsoil is a bit cheaper so leaning towards them. for rp i would probably do there maxgear 75w90 and then there synhcromax im guessing?
thanks!!
thanks!!
After my buddies H2 tcase was found with a pile of metal shavings when opened after using recommended transmission fluid,, starting at 78K miles, I change my front, rear diff and tcase oil every 30K miles with 75w 90 gear oil. At 258K now with no issues.
Just changed my transfer case fluid. When I drained I got almost 3 quarts of fluid out. But when I tried to fill the required 2.5 quarts it only took a little less then 2 until it started pouring out. Is that something I should be worried about
You got 3? Transfer Case Oil Capacity Borg Warner 4484 1.5 quarts
i used royal purple manual transmission fluid, seems to be a replacmenet for dexron 3 and a bunch of people on youtube are using it for our trucks
