De-Chroming w/ Rust-Oleum Spray Paint
Old 12-26-2020, 04:07 PM
Chad James's Avatar
Originally Posted by UcraDen
I normally don't like paintvthe plastic, let alnoe the parts you'll touch all the time, because the paint doesn't hold on properly.
I paint the chomed and cracked grill on my hummer, just because I couldn't find proper replacement, we will see how long it will work...
Normally to make proper job, you should remove the chrome completely. To do such from my mags, I spent 800$ for 5......
I will definitely keep you guys updated in terms of longevity. It was a quick and easy option. But maybe not the best. But time will tell for sure.
Old 12-28-2020, 11:01 AM
Chad James's Avatar
wow, seems expensive. But obviously sounds like the best way to go for a more permanent finish. I’ll definitely keep everyone updated on the longevity.
Old 12-28-2020, 11:04 AM
Chad James's Avatar
Give plenty time to cure, dry heat best to cure, then a coat or 2 with clear acrylic sealer.
hmm, I didn’t event think to use clear acrylic sealer. I’ll have to get some and throw a coat on. Thanks for the suggestion.
Old 12-28-2020, 11:51 AM
Broken Halo's Avatar
If you go with polyurethane clear coat (tough stuff) use water base not oil base. The oil base tends to have a yellowish tint to it. Ask me how I know.
Old 12-28-2020, 08:49 PM
Chad James's Avatar
perfect tip, and much appreciated!
Old 12-28-2020, 08:52 PM
Chad James's Avatar
Good from far, but not bad up close.
I’ll eventually throw down a clear coat to finish it off. Possibly another coat of paint before hand.
There are blemishes, not perfect. But I do really like the color.
Old 12-28-2020, 09:06 PM
Handle looks good to me, protect with sealer. Also give your fender a new coat.
Old 12-29-2020, 09:58 AM
Soon as you loose the Nurse Bars, you'll have a nice looking rig.
Old 12-29-2020, 11:00 AM
Chad James's Avatar
lol 😂 agreed!
Hbrezzi
01-26-2019 08:52 AM
Tonyg41
05-07-2010 12:04 AM
finseeker
03-17-2008 11:59 AM
2zRescue
22
12-08-2007 11:00 PM
HummerGuy
07-16-2007 11:50 AM
Quick Reply: De-Chroming w/ Rust-Oleum Spray Paint
