Daytime running light upgrade
One of the last things in fixing up my H2 was those daytime running lights, pretty old and dull looking. Read a lot of postings were people improvised and modified the bucket where it mounts. Trying to keep everything intact and didn't want to butcher anything. Finally found a set that are made for the H2, LEDs with a Halo and glass lenses. $188 and a direct plug-in to the factory harness, with one additional wire if you want to run the lights with your headlights on or with a switch. They're fairly bright so I tapped into my high beam wire behind the headlight and run them with the high beam. When the daytime running light circuit is activated the halo around them lights up. Made in China, shipped from China, but sold on Amazon so I figured why not check it out and I can always return for free. Actually they were very good quality, packed in rubber foam. The glass lenses say dot SAE, but who knows for sure. Below the info if anyone's interested. Can't believe I'd actually recommend something from China!
H2 Led Halo Fog Lights Replacement for Hummer-H2 2003 2004 2005 2006 2007 2008 2009 White Led Fog DRL Daytime Running Light 12V Led Angel Eye Driving Halo Fog Lamp Kit GM#15258697, 15205899 https://a.co/d/3LR541Z
Chiefmmc
07-09-2021 08:16 AM
