Dash and windows out.
I have a 03 h2. For some reason the dashboard, radio, and widows quit working. The speedometer and tachometer still work. It also says unknown driver but will still run and drives fine. I've done the reset for unknown driver and it didn't help. If I put the car just in on position and not crank everything works. Anyone else had this problem?
- What was the last work you did, any modifications, changes or replacements?
- Is there any aftermarket equipment such as an alarm, remote start, tracker etc.
- What is your battery's SOH (State Of Health) and SOC (Charge) ?
- Any water leaks or ingress anywhere (DDM PDM BCM)
- Air suspension - connectors, condition, any past issues?
It sounds like a communications issue that only occurs when "HOT IN RUN" this a circuit that goes to a few modules which have serial comms, e.g.:-
BCM, HVAC, Air Suspension (the latter two can be easily unplugged to test)
It could be a failing module or a corroded/contaminated connector and may take a bit of detective work to trace.Splice Pack 205 might be a good place to start, suggest watching
Hopefully this info is useful, so please feedback anything you find which could be useful to other members with similar issues.✔️
Good luck!
[Awaiting Resolution]
Heart of chrome
11-28-2014 07:51 AM
potroast
12-14-2013 11:27 AM
