Crankshaft sensor location
I only have a simple ODB code reader so made a call to a local garage, told the guy I drive a 2006 H3 and replaced the crankshaft sensor. He told me to simply disconnect the battery for 10 mins so everything is clears and it will relearn, but if I didn't want to do that, bring it to his shop and he'll charge me $180 to do it with software.
Is that correct, different procedure for the same result? Is the scanner/software relearn procedure required for some reason, or will it relearn after disconnecting the battery then going for a test drive? Thanks!
To be perfectly honest with you I have heard you can force the ECM to do a relearn with a battery disconnect but this was for the throttle position sensor but not for the crankshaft sensor. You could try it and have nothing to loose and $180 to gain if it works.
Perhaps DocOlds can comment on this as he has an H3 with I5 so he would know.
Yeah, I'm thinking I may just do that.
I didn't want to start grilling the mechanic on the phone if he was 100% sure, but he basically said "whichever way you want to do it", disconnect the battery or pay me $180 to do it with the scanner.
Ernes Isakagić
05-24-2016 02:09 PM
ezekielj007
08-20-2014 07:32 AM
C31322
09-11-2013 03:27 PM
powerboat
06-26-2012 09:06 AM
