Coil spring retainers?
I’m in Oklahoma. I was just curious if the Hummers with OEM rear coil suspensions came with any sort of retainer or not. I couldn’t find anything showing there was. I’ve never had any coil suspensions without them in the past (all Jeep).
My kit didn't come with any either and just what I thought, the pass side slipped off a few days after installing. I had the air suspension. So it rubs on the sleeve at times. I don't understand why these kits don't come with something to hold them in the center. Now, I'm thinking about putting the airbags back on though. I bought a pair of airbags first then changed my mind and bought springs because I didn't want to worry about them deflating ever again. But now I don't know. Air leveling is nice too. And it's not that hard to replace them even if I had to do it every 3 or 4 years.
What was your driving condition and speeds like when it slipped off? Was yours the FabTech 6” springs and did you have the driver and passenger coils on the correct sides with closer compression coils towards the axle?
I don’t understand how it’s possible for it to slip off?
if your installing the springs on the correct side (LH is different than RH) installing them in the correct up-down position and bringing the weight back down onto the springs I don’t possibly see any way for the springs to come off.
There’s a lot of weight and tension on the springs and even flexing my axle without the sway bar I’ve never been close to dislodging the spring.
Look here - https://nemigaparts.com/cat_spares/e...n/07/tn07-005/
You have part # 13 right? Those insulators are also retainers to an extent. The center part of those sticks up about a half an inch and the insulator itself also has some thickness (I think it is maybe 1/4" but when you have that on top and bottom missing the springs end up being about a half an inch too short). The springs need those.
Those are different isolators than what my kit had. They were just flat and 1/8" thick like a washer. Their only purpose was to prevent noise, not keep the spring in place. There is a slight flange on the circular part in the middle of that cylinder sleeve but it is not enough to keep the springs centered. But the springs won't ever come completely out as you can see in the second pic because of the sleeve. I don't need that style for the bottom at least. I left the stock bump on and that works great plus the new rubber isolator. The top, it might help. I'd have to see an actual picture of the isolator first, I can't tell by that diagram.
