Brake, ABS and TC lights randomly come on
Old 01-10-2024, 07:22 PM
H2-SUT's Avatar
Floorman, that all depends on your mechanical ability and your willingness and dedication to work on a 19 year old vehicle.
A couple of other things to consider is: vehicle mileage, frame/body condition, how molested it is? These things all factor heavy into the actual worth of the H2.
Old 01-10-2024, 07:46 PM
Floorman's Avatar
The frame and body is 9 out of 10. Interior is 7 out of 10. But I am mechanically inclined but I need something reliable. I don't mind getting a little greasy.
Old 01-10-2024, 07:52 PM
H2-SUT's Avatar
You forgot to mention how many miles were on it, the year and if its a 5 or v8? Those are biggies!
Old 01-10-2024, 08:11 PM
Floorman's Avatar
Originally Posted by H2-SUT
You forgot to mention how many miles were on it, the year and if it’sa 5 or v8? Those are biggies!
It has 163k on the replacement engine, 2005 v8
Old 01-10-2024, 09:43 PM
H2-SUT's Avatar
Ok, that changes alot, where did the engine come from, is it a LQ4 6.0 liter?
Old 01-10-2024, 09:44 PM
Floorman's Avatar
This is a H2
Old 01-10-2024, 10:05 PM
H2-SUT's Avatar
If the engine is an LQ4 6.0 liter and was a simple transplant from a GM truck and runs well the other issues are not big ones. 6K would not be out of line for it. Unless you have a trans problem other things won't be to expensive to resolve.
Old 01-11-2024, 09:46 AM
check the wiring that goes to the ABS module it is located drivers side top of frame rail. maybe when installing the motor something got pulled or pinched
Old 01-11-2024, 01:40 PM
Gavin Costigan's Avatar
If only everyone had a professional level scanner or a tech ii. Makes things so much easier. Without it you’re just shooting in the dark. Check the condition of your wheel speed sensor wires.
Old 01-11-2024, 04:43 PM
Floorman's Avatar
Which scanner do you recommend?
Quick Reply: Brake, ABS and TC lights randomly come on
