Air suspension question.
Hi All,
I’m a fairly new H2 owner.
I have had some problems with the air suspension and have just changed the suspension sensors to new ones. I would be grateful if someone could explain if my air suspension works correctly.
Before I start the engine, the air suspension is at its lowest position. When I start the engine I could hear the compressor and the suspension raise about 7-10cm and then the compressor stops.
I think the suspension started at a much higher position before the sensors where changed.
Do they work as intended now, or should the suspension maintain it height when the engine is off?
Random-Hero-
04-01-2012 10:58 AM
RedRocker
04-27-2009 10:53 AM
