Aftermarket lights to replace the round DRL lights
#71
Mixman, did you run new wires to the Tacoma fogs or utilize the drl circuit from the fuse box forward ? I’d like to not cut my wiring. It’s an odd looking plug for the drls. Might be hard to find the mating plug to make an adapter cable though.
#72
For the fog light function I had to run new wires. For the DRL function (halo's on the ones I bought) I did not cut the factor wires but if I remember right I had found some other plugs that fit the factory plugs and spliced them onto the wires for the lights I added to plug into the factory DRL plugs.
#74
Nice! Those ladders are not cheap.... That roof rack, if not all bent up, would be nice to have. With another vehicle set on top though, it might be trashed. I've been wanting one for a long time but just have not been able to afford one.
#75
actually that roof rack looks like its in good condition with only surface rust, but you're right with that car on top, I'm sure there is some damage I can't see. I'm looking for an OEM gas locking door and that rear tire tag light cover NOT the full tire cover..any leads? I found an H3 with the gas locking door, but I'm not sure if it will fit the H2 or if they have the keys to it. Also, what type of adhesive can I use for these tail light guards and don't you have to drill at least one hole for the gobi ladder? I real don't want to put a hole in the mold and rear tail gate. The website claims "no drilling necessary," but the schematic I found online requires at least one hole drilled.
#77
Thinking about doing the entire h2 with raptor liner.....although I would love to go with a Vantablack paint job.
www.youtube.com/watch?v=tMFMmkQ_kHo
#80
Does anybody know how this guy put the lightbar inside the roof rack or did he buy it like this? I was about to do a 52 inch roof light bar mount, but have heard bad things about wind noise. Check out this link..The guy put the lightbar inside the front roof rack
