ABS Module
Old 11-02-2021, 05:07 AM
oceanbrave's Avatar
Originally Posted by Hummertime1
Yeah he said to check to see if the wiring entering the connector was protected by plastic seals. I can't see anything like that so I think they are not sealed. Just the abs module is sealed as you said.
The ABS Module and associated connector would have to withstand being wet one, these vehicles go off-road over various terrains, through rivers too.
There must be something to make them water-resistant, either the connector housing itself, little rubber grommets pushed over individual wire and into the housing (fairly typical) or as finall's post suggests.
Also see the Delphi part (APTIV) description below:-
Actually things gets more complicated by the minute, I just found the attached PDF.
Also found a site called CustomConnectorKits it may help shed some light, may even be able to help
If you Google "GT 150 280" in quotes, you'll find lots of related info, i.e. this connector on eBay, it's not what you want, but it visually may help, maybe the pins and fittings are the same?
Even Farnell sell some APTIV connectors etc.
It may be worth directly contacting APTIV here, they may be able to advise or source what you need.
File Type: pdf
  #32
Old 11-03-2021, 05:37 AM
Hummertime1's Avatar
I think I may have found the harness I need - can anyone confirm that this is it? It's off a 2004 Hummer H2 and says engine harness which includes abs.
  #33
Old 11-03-2021, 09:23 AM
oceanbrave's Avatar
That's a tough question....I'll try and work it out...
  #34
Old 08-26-2022, 05:28 AM
oceanbrave's Avatar
Hummertime1 did you ever get this sorted?
ulthummer
Private 'Wanted' Classifieds
12-03-2021 05:45 PM
achoukair
01-14-2019 12:58 PM
mnorrick1
04-05-2016 06:57 AM
Yuriy Sylovanyuk
12-03-2012 08:53 PM
maz722
11-04-2011 11:02 AM
Quick Reply: ABS Module
